Flat cable assemblies shall not be installed outdoors or in wet or damp locations unless _____ for the use.
a) special permission is granted
b) approved
c) identified
d) none of the above
The correct answer is: c) identified
Article 322 covers the use, installation, and construction specifications for flat cable assemblies. As noted in Sec. 322.12(4), flat cable assemblies shall not be used "outdoors or in wet or damp locations unless identified for the use."
