Grounding Rules for Panelboards
Feb. 9, 2015
Part III of Article 480 focuses on panelboards.
When separate equipment grounding conductors are provided in panelboards, a ______ shall be secured inside the cabinet.
a) grounded conductor
b) terminal lug
c) terminal bar
d) none of the above
The correct answer is: c) terminal bar
Article 408 covers switchboards, switchgear and panelboards. Part III of this Article focuses on panelboards. As noted in the second sentence of Sec. 408.40, "Where the panelboard is used with nonmetallic raceway or cable or where seprate equipment grounding conductors are provided, a terminal bar for the equipment grounding conductors shall be secured inside the cabinet."
Mike Holt
