Product News
AC voltage detectors The 1AC-II and 1LAC-II pocket-sized AC voltage detectors are CAT IV 1,000V over-voltage rated, with voltage sensing ranges from 90VAC to 1000VAC and 200VAC to 1,000VAC, respectively. The testers feature the company's VoltBeat continuous self-test capability, which continually scans for battery performance and circuit integrity and produces a periodic double flash that indicates
The 1AC-II and 1LAC-II pocket-sized AC voltage detectors are CAT IV 1,000V over-voltage rated, with voltage sensing ranges from 90VAC to 1000VAC and 200VAC to 1,000VAC, respectively. The testers feature the company's VoltBeat continuous self-test capability, which continually scans for battery performance and circuit integrity and produces a periodic double flash that indicates the device is working properly.
Fluke
Circle 250
Child-resistant wallplate
A child-resistant wallplate is the latest addition to the Kiddy Cop line of child protective wiring devices. The compact wallplate, available in ivory and white, is designed to blend with most wall surfaces. It fits over a standard duplex grounding outlet and has a sliding mechanism that permits easy access by adults, but requires a greater level of manual dexterity than most small children have developed. This wallplate is UL listed and CSA and NOM certified.
Leviton
Circle 257
Can light tool set
This recessed can light tool set is designed to install recessed can lights quickly and easily. The set includes a 6-in. cushion-grip spring tool to help users prevent bending, breaking, or dropping of the spring. The C-tip helps keep the spring from slipping out of the tip of the tool, and a chrome-plated shaft resists corrosion. The set also includes a hollow-shank stubby nut driver with a 1½ in. shank that fits ¼-in. hex nuts.
Klein Tools
Circle 254
Cable roller guide
The CR25 cable roller guide is designed to guide and protect cables during installation. This guide is ideal for Cat. 5, Cat. 5e, and Cat. 6 cable installations as well as those using small diameter cables, such as coax, NM, and small THHN. The unit's clamp allows it to be attached to cable trays, raceways, studs, joists, or anywhere there is a need to run and guide cable. The guide's nylon rollers not only help prevent damage to the cable but also minimize the force required to pull the cable into place.
Greenlee
Circle 252
Hole saw kit
This line of hole saw kit boxes has 15 new configurations, including nine bi-metal hole saw kits, four carbide tipped hole saw kits, and two sets of the company's One Tooth rough wood hole cutters. One of the new configurations is a compact version of the company's 600L and 600P bi-metal hole saw kits. All kit boxes feature metal hinge pins and metal yoke latches.
Lenox
Circle 259
Cable/pipe clamp
Cobra is a one-piece cable and pipe clamp, featuring a pre-threaded bolt with universal bolt head that accepts a wrench, screwdriver, or nut driver. The clamp has a rugged stirrup and wide saddle design for attaching equal trade sizes of EMT, rigid conduit, and cable to strut channels. It works with all depths of strut from 13/16 in. to 3 ¼ in. Available in 316 stainless steel or electrogalvanized steel, each piece is marked to identify the catalog number, minimum/maximum outer cable diameters, EMT/Rigid trade sizes, and CSA and UL stamps.
Thomas & Betts
Circle 256
Hide comments
Comments
Plain text
  • No HTML tags allowed.
Publish
