The FLIR CM174 Imaging 600A AC/DC Clamp Meter is the only clamp meter with the power to lead you to problems you can't see with a standard clamp meter. Featuring Infrared Guided Measurement (IGM) technology powered by an integrated FLIR Lepton® thermal imaging sensor, CM174 visually guides you to the precise location of a potential electrical problem, identifying dangerous and unknown problem areas safely. Learn more: FLIR.com/CM174
