Code Quiz: Mounting a Box with Screws
Aug. 17, 2017
NEC Rules on Mounting a Box with Screws
Fill in the blank. When securing a box, screws shall not be permitted to pass through the box unless exposed threads in the box are ______ using approved means to avoid abrasion of the conductor insulation. Mounting holes made in the field shall be _______.
A) coated / threaded
B) painted / tapered
C) protected / approved
D) covered / identified
Scroll Down to See the Answer
Answer: C
As outlined in a portion of Sec. 314.23(B)(1), “Screws shall not be permitted to pass through the box unless exposed threads in the box are protected using approved means to avoid abrasion of conductor insulation. Mounting holes made in the field shall be approved.”
Steven Owen
Strut Corrosion Guide
