The 180XL Visual Fault Locator is designed to quickly visually locate macrobends, poor splices, bad connectors, and breaks in fibers. Featuring a universal 2.5-mm bulkhead, the fault locator is able to probe single-mode and multi-mode fibers. An optional 1.25-mm adapter is also available. In addition, the handheld, Class 2-compliant device can be used to confirm fiber continuity on fibers up to 7 km in length and a 2-Hz modulation can be used to aid continuity confirmation.
Greenlee Communications
