The UESL End Seal Signal Light Kit provides visual warning that a heat trace circuit is energized. The NEMA 4X-rated end seal is designed to terminate one cable and indicate power with a universal voltage LED indicator light. Featuring a single piece clamshell that eliminates all screws and reduces the number of tools needed to install it, the product offers 360° visibility. In addition, one unit is suitable for 120V through 277V. The device also provides water-resistant cable entry and corrosion-resistant wiring enclosure.
Chromalox
