The Control Pro Series consists of passive infrared (PIR), ultrasonic, and multi-tech (PIR, ultrasonic, daylighting) occupancy detectors. Designed to control lighting as well as HVAC in a variety of commercial applications, the products’ control interfaces (load modules) accommodate numerous installation choices, including line voltage or low voltage for use with a power pack or control panel. The devices can be mounted on the ceiling to provide 360° coverage. In addition, models are available that mount in the corner or on a wall and achieve a 180° view of the space. Other features include a 0V to 10V dim option, KNX interface module for direct use with the international standardized (ISO/IEC 14543-3), and harmonized US Standard (ANSI/ASHRAE 135) network-based communications protocol for intelligent buildings.
Steinel
