PROmax power supplies feature start-up at temperatures as low as -40°C, hazardous area approvals (UL, Class 1, Div. 2), and a 300% power boost. Designed for control panels specified for use in harsh environments as well as heavy industrial applications, the products offer an all-metal housing and DIN-rail mounting foot to ensure mechanical shock- and vibration-resistant operation. The power supply family includes 16 models with 5VDC, 12VDC, 24VDC, or 48VDC outputs for loads up to 40A. Voltage output may be adjusted via the front panel. and either series or parallel operation is standard on all units. A two-color LED provides local status output and remote status monitoring is delivered through integrated relay contacts.
Weidmuller
