Ecmweb 7451 Ilsco Nimbus Motors Preinsulated Connectors
Pre-insulated connectors
June 2, 2015
Available as single catalog numbers or as pre-configured kits Screw design improves vibration resistance Designed to simplify Megger testing for motors
The NIMBUS 4FLEX line of pre-insulated connectors has been enhanced to include NIMBUS Motors. NIMBUS Motors is available to order as single catalog numbers or as pre-configured kits for specific motor applications. With NIMBUS Motors, users can mix any class of copper and/or aluminum conductor without concern for expansion, contraction, and galvanic corrosion. According to the company, the screw design improves vibration resistance, compresses conductor without damage, and eliminates the need for ferrules, making it reusable. The kits are designed to simplify Megger testing for motors. The product offering features color-coded screw caps with embossed lettering to simplify motor hook-up. In addition, the connectors are UL-listed, CSA-certified, RoHS-compliant and dual-rated for copper or aluminum conductor.
ILSCO
