Focus on Specialty Products
Nov. 1, 2008
Inspection window The Viz-IR inspection window maintains a guard between the user and energized electrical conductors and circuits eliminating the need for elevated levels of PPE per NFPA 70, according to the company. The window combines broadband infrared inspection and visual inspection in one panel. For added safety, installation hardware is concealed behind the panel door. An optional factory-fitted
Inspection window
The Viz-IR inspection window maintains a guard between the user and energized electrical conductors and circuits — eliminating the need for elevated levels of PPE per NFPA 70, according to the company. The window combines broadband infrared inspection and visual inspection in one panel. For added safety, installation hardware is concealed behind the panel door. An optional factory-fitted Ultrasound Port (for use with ultrasound detectors) for detecting corona and tracking faults is also offered.
Iriss
Circle 300
Business graphics software
SmartDraw 2009 business graphics software contains enhanced functionality, according to the company. Additional improved features include seamless PowerPoint integration with built-in animation; faster project management; quicker flowcharting; enhanced ImageCharts and ExpressCharts; automatic mind maps and org charts; realistic Live Maps with Google; and smart Web site mapping.
SmartDraw.com
Circle 301
BIM software
SmartBIM Library 3.0 is an add-on to Autodesk's Revit building design software that allows users to store, organize, and locate BIM objects. According to the company, new features provide the ability to open multiple libraries as well as merge content between libraries. In addition, version 3.0 is pre-loaded with more than 14,000 Revit family types.
Reed Construction Data
Circle 302
LED tester
The LED Engineering Kit allows users to test LEDs with various accessories and applications. The kit includes the company's OSTAR high-power LED as well as components from various LED Light for You (LLFY) partners, including lenses and reflectors, a power supply, thermal interface material, and a selection of heat sinks. A brochure is also included for technical assistance.
Osram Opto Semiconductors
Circle 303
