Utility Luminaire
This UL-listed wet-location utility luminaire is resistant to corrosion, UV light, and high-impact and high-pressure wash down. Able to install using only a screwdriver, the luminaire features an 18-cu-in. junction box for addition of another power circuit. Eight mounting brackets on the junction box are in line with the ½-in. and ¾-in. trade-size knockouts to eliminate a 2 in. × 4 in. stub-in. Other features include an optional impact-resistant, quarter-turn safety cage that attaches to the junction box without tools; a junction box cover with a captive set screw and posi-stop detent, and a nickel-plated brass screw shell recessed approximately 1 in. in the junction box cover that accommodates high-profile CFL or incandescent lamps (150W max).
Engineered Products
Circle 250
Weld Material Storage Containers
NUWTube keeps exothermic weld materials separated until ready to use. Featuring a dual-chamber design, the containers hold the starting material and weld metal separately in one tube, each accessible and easily identifiable by a color-coded cap. Users simply remove the clear cap to pour the weld metal into the mold, flip the tube over, and then remove the orange cap to add the starting material. The product also features recyclable outer packaging.
Harger Lightning & Grounding
Circle 251
Duct Spacers
Carlon Snap-N-Stac combo duct spacers combine the traditional two-piece base and intermediate spacer systems into a single, one-piece unit. Featuring a horizontal locking system and vertical locking system that enable the product to be used as a base or intermediate spacer, the products are available in one-way, two-way and three-way configurations. In addition, the spacers can be installed horizontally, vertically or turned upright for duct bank configurations. A molded-in rebar holder is available in two- and three-way configurations. One- and three-way configurations are available for 2-in.-and 4-in. duct, while two-way configurations are available for 2-in., 3-in., 4-in., 5-in. and 6-in. duct.
Thomas & Betts
Circle 252
Drop Wire Support
Wire Grabber (#FLG3) offers secure hanging support of static loads requiring drop wire support, such as luminaires (including high-bay), boxes, cable tray, and more. Suitable for use in dry or wet locations, the product’s hold on galvanized braided wire is unaffected by oil or grease, according to the company. In addition, it holds angular and other static loads up to 100 lb.
Arlington Industries
Circle 253
Electric Vehicle Charger
This Level 1 electric vehicle (EV) charger enables users to meter their EV’s electricity consumption and communicate data via a smart charging cord and socket. The smart cord features an SAE J1772 connector and works in any 120V receptacle. In addition, the cord includes a charging status light bar that illuminates during charging as well as a dashboard conveying the price of electricity. Electric utilities can control the device via the smart socket to enable demand response during peak periods. Inline safety circuitry protects the system and users. The smart socket fits over a standard 120V receptacle without the need for any electrical wiring, site permitting, or inspection. In addition, the socket meters the electricity consumed by the EV and includes anti-theft, anti-tamper security mechanisms.
TE Connectivity/Plug Smart
Circle 254
Continue to Page 2
LED Replacement Lamp
R16 LED reflector lamps feature a standard 26-mm medium screw base, operate on 120VAC, and provide a concentrated 40° beam of light from a cluster of 40 LEDs. The R16-40-SIW-120AM (3,000K warm white) and R16-40-TPW-120AM (5,000K natural white) draw 1.7W each and provide up to 140 lm. According to the company, the products provide up to 90% savings in energy costs over incandescent and halogen lamps and offer an operating lifespan of up to 50,000 hr.
Ledtronics
Circle 255
freeproductinfo.net/ecm
Takeoff Software
For users with access to only PDF or TIF images rather than native CAD drawings, LiveCount Pro provides paperless on-screen takeoffs, an auto-count feature, as well as seamless integration with Accubid’s Estimating and ChangeOrder solutions. Featuring a 2-way live link between the raster drawing and the Accubid job, the software allows takeoff edits to be initiated from the LiveCount side and automatically updates the audit trail when quantities are changed in LiveCount Pro. The Auto Count feature offers accurate symbol recognition capability that features a unique way of displaying search results that allows for easy identification of objects found in the drawing.
Trimble
Circle 256
Underground Puller
The APS75 hydraulic underground cable puller provides up to 7,500 lb of continuous pulling power. Completely self-contained, the puller features a digital readout that allows users to view pulling forces, distance pulled, tension limiter, and hydraulic pressure readings. Pulling operations can be recorded and downloaded through a USB port. Additional features include anti-twist rope, rotating pulling arm, and wired remote control.
Condux International
Circle 257
Data Logger
The HOBO UX90 occupancy and light logger is a matchbox-sized, LCD-display data logger that tracks building occupancy and light usage to pinpoint areas in a building that could benefit from occupancy sensors and other energy-saving initiatives. The data loggers collect time-stamped data documenting each time room occupancy or lighting status changes. In addition, the device can be mounted to a luminaire, ceiling, and or wall, and can be set up and installed in less than 1 min., according to the company. Once data has been recorded, it can be viewed in graph form using accompanying HOBOware software and printed out. The data can also be exported to Microsoft Excel.
Onset
Circle 258
Tool Bags
Designed to exceed loaded weight requirements and withstand extreme use conditions, these soft storage tool bags are available in four models. The Electrician’s Tote has eight interior pockets, 12 external pockets, five open storage areas, and 16 elastic loops. It includes a tape measuring clip, key clip, tape holder loop, and small parts bin. A clip-on handle allows the tote to be hung anywhere. The Bucket Tool Organizer features 22 exterior pockets and 12 internal pockets. It includes a hammer loop, tape-holder loop, and side clips. LenoxCircle 259Continue to Page 3
Pipe Clamps
These UL-listed pipe clamps feature swivel hubs that swing 360° degrees for easy alignment to rigid conduit while saddle clamps on the hubs make grounding connections simple and secure. Cast from a highly conductive copper alloy, the pipe clamps come with or without a copper strap. Model GC11-CSLH, which features a solid copper strap between the hub and clamp, is sized for ½-in. to 1-in. pipe and assembles ½-in., ¾-in., and 1-in. conduit. The copper strap allows flexibility during grounding and helps protect the conduit system from the effects of vibrations in water pipes. Strapless models are designated GC11-LH (for ½-in. to 1-in. pipe), GC22-LH (for 1¼-in. to 2-in. pipe) and GC4-LH (for 2½-in. to 4-in. pipe). All models are available in configurations for ½-in., ¾-in., and 1-in. conduit.
Galvan Electrical Products
Circle 260
High-bay Luminaires
T5 HighBay luminaires feature pre-installed occupancy sensors as well as a 90% enhanced, high polished reflector. Designed with a universal voltage ballast that offers a hinged door for access without taking down the luminaire or the use of tools, the product is also available for special order with the company’s high-efficiency ballast factor universal ballast. Available in 4-lamp and 6-lamp configurations, the luminaires operate on 120V and 277V systems, and each fixture includes a 10-ft-long, 3-wire cord with plug.
MaxLite
Circle 261
Soft Starters
The Stellar SR33 Series of basic soft starters is designed for general-purpose applications where traditional across-the-line starting or wye-delta starting would typically be appropriate. The semiconductor soft starters, available in 22A to 482A sizes, are suitable to control 3-phase AC induction motors with a variety of motor loads. All units feature 2-phase control, separately adjustable motor start voltage and start/stop times, and depending on model, fault indication of four or seven fault types: SCR or power supply, overheat, control power supply, bypass relay failure, shear pin, overload, and overcurrent.
Automation Direct
Circle 200
Outdoor LED Lightbar
The outdoor LED LightBAR features the company’s AccuLED optics. Featuring an application-specific design that allows lumen and energy output to be customized to fulfill the exact needs of the outdoor space, the lightbar is available in 7 LED and 21 LEDs versions; features color options of 3,000K, 4,000K, and 6,000K CCT, and comes in 13 different optical distributions. In addition, the product is backward compatible or future-proof both electrically and thermally and offers a 50,000-hr life, according to the company.
Cooper Lighting
Circle 201
LED Emergency Luminaire
The FDBAES Series of flameproof, self-contained emergency luminaires delivers lighting and/or visual indication of safe access on exit routes during an evacuation in a hazardous industrial environment, including areas defined by the IEC as Zone 1, 2, 21, and 22. Models designed for escape lighting produce
55 lm, consuming a total of 0.5W. In the event of an emergency, the luminaires will run for a 1-hr duration on the built-in battery pack. Models for space lighting applications produce 540 lm, consuming a total of 0.95W. Both versions are equipped with six white LEDs rated for 60,000+ hr, according to the company. In addition, either version can be ordered as switched or unswitched, and as addressable.
Appleton
Circle 202
Fluorescent lamp tester
The Fluorescent Lighting Tester tests all T5, T8, and T12 fluorescent lamps and allows users to troubleshoot an entire building in half the time, according to the company. Featuring a 2½-ft, fully retractable antenna, the product includes a removable antenna adapter to increase “flicker” response, audible and visual indicators for easy readings, a built-in LED work light, and a rugged over-mold grip. Additional features include four AA batteries, manual, and carrying case. Milwaukee Electric ToolCircle 203Current-Sensing Switch
The AS1 Series compact case current-sensing switch features a 1-in. housing. Designed to monitor an energized circuit in tight spaces, the switch includes a ring design that easily slips onto a conductor to detect currents as low as 0.5A with a single conductor pass, eliminating the need to wrap conductors multiple times. Rated for use in ambient temperatures ranging from -4°F to 122°F, features include 24-in. leads that can be connected directly to controller input terminals or brought out to a terminal block to facilitate remote operation. The contact can control either AC or DC circuits to 120V, with a maximum load capacity of 150mA. Near zero off-state leakage provides positive indication of the presence of AC current, and the output can handle the coil of an industrial-quality relay.
NK Technologies
Circle 204
Enclosures
When combined with the company’s EZCan hardware mounting kits, the UL-listed EZCan line of modular electrical enclosures can house most major OEM’s electrical circuit breakers between 250A and 1,200A. The enclosures are currently offered in 14-gauge Jet Coat A60-type steel with powder-coat finish to meet NEMA 3R environmental requirements. The units are available in other materials and finishes on request.
Romac HRC
Circle 205
Training Software
Troubleshooting PLC Circuits 1 simulation-based troubleshooting training software teaches users skills needed to troubleshoot PLC-controlled equipment and systems. Program features include: in-depth videos and more than a dozen hands-on labs to understand PLC operations, 12 practice exercises and guided faults on a basic PLC controlled circuit for troubleshooting practice, and three PLC troubleshooting scenarios with more than 45 challenging malfunctions to diagnose and repair. Available in North American or European design standards, the software provides detailed feedback on users’ troubleshooting process and comprehensive evaluation of their troubleshooting skills.
Simutech Multimedia
Circle 206
Plugs and Connectors
Smart Monitor plugs and connectors continuosly monitor a facility’s cordsets. Styles include Perma-Link cord clamp style with an internal cord seal and dual screw self-centering clamp; Perma-Grip cord grip nut style that features nickel-plated solid brass blades and super sealing cord grip nut design; and Perm-Tite2 all-weather cord grip nut style, which is all-weather NEMA 6P rated and features super sealing rings, nickel-plated solid brass blades, and a super sealing cord grip nut. Other features include LEDs with four sealed ports around the perimeter, keyed body and cover, non-slip finger grip, and rubberized outer body.
Ericson
Circle 207
Emergency Lighting Controls
The UL924 emergency lighting control relay (ERC) mounts in the ceiling and features an automatic diagnostic feature to replace the need for an accessible test switch. When lighting is turned off in a room, the emergency luminaires stay on for an additional 2.5 sec to verify the emergency power source and that lighting is functioning correctly. The UL924 emergency lighting dimmer control (EDC) turns lights on to full brightness in an emergency. The EDC is available in 120V and 277V models and includes a test switch. The UL924 emergency lighting control relay (panel-mount) (EPMC) is a universally compatible device available in 120V and 277V models. The test switch allows users to test their emergency lighting system with the press of a button, and a green LED confirms wiring connections and power availability.
Schneider Electric
Circle 208
Gen-Set
Offering up to 3.5MW of power, the C3000 Series gen-set incorporates the company’s 95-l QSK95 engine, which features the Modular Common-Rail System (MCRS) with up to 2,200-bar high-pressure fuel injection. The gen-set also has the ability to meet EPA Tier 4 Final emissions taking effect in 2015. The Selective Catalytic Reduction (SCR) aftertreatment system is intended to replace the exhaust muffler on the gen-set.
Cummins Power Generation
Circle 209
Cable Divider System
The Barrier Bridge is designed to solve the challenge of dividing cables running in the same cable tray at horizontal tees and crosses. The system includes a cable bridge, an elevation brace, a standard barrier, and standard hardware that can be used with all ladder tray materials and heights. In addition to addressing NEC compliance, the product features smooth, hemmed edges to protect cable jackets and raised sides of the top level that retain cables without rising over the height of the cable tray. CAD details and submittal sheets are available online
Cooper B-Line
Circle 210
Outdoor LED Luminaires
The AeroScape Series of outdoor LED luminaires is designed as a 250W and 400W HID equivalent while consuming up to 60% less energy, according to the company. The luminaires offer multiple distribution patterns, efficacies up to
86 lm/W, and full range dimming capability. A passthrough convective cooling system helps the product achieve an
80,000-hr rated system life. Additional features include rotatable optics, upgradability, and IP66-rated construction.
Philips Wide-Lite
Circle 211
Transformers
Uniclad dry-type transformers offer an alternative to traditional cast coil transformers. Suitable for use in hazardous or harsh environments, indoor and outdoor, the transformers are available in several types of enclosures, including totally enclosed non-ventilated for operation in environments with corrosive gases, high amounts of dust, or other contaminants, or where the environmental conditions include high humidity or excessively high or low temperatures. In addition, the units are available up to 15MVA, 35kV class, 150kV BIL.
Virginia Transformer
Circle 211
Busway
B800 track busway is offered in two style options: copper (all copper conductors) and composite aluminum (continuous copper contact surfaces with aluminum busbar). Features include: 800A/600VAC or VDC, continuous access or plug-in/shutter design, aluminum housing, and interchangeable plug-ins with B250 and B400 systems. Both systems are available in customizable lengths in sizes up to
10 ft or 4 m.
UEC/Starline
Circle 212
UPS
The Quint UPS-IQ rail-mounted uninterruptible power supply (UPS) features the company’s IQ technology. The intelligent battery modules provide users with critical data, including charge state, remaining buffer time, and expected lifetime. The IQ technology also displays all relevant data on the unit’s front panel or transmits it to a computer. For 24V loads, the UL 508- and 1778-listed UPS features output currents of 5A, 10A, 20A, and 40A, while the AC version has an output power of 500VA.
Phoenix Contact
Circle 213
