Single-phase power supplies
This line of UL1604, Class I, Division 2-approved 24VDC single-phase power supplies features an auto-ranging input, wide operating temperature range, and a UL508C listing. Available in 1.5A, 3.5A, 5A, and 10A versions, the power supplies are suitable for use in applications where fire or explosion hazards may exist.
Automation Systems Interconnect
Circle 300
Double-conversion UPS
The Liebert GXT3 uninterruptible power supply (UPS) is available in 5kVA to 10kVA models. An extension of the existing product line, this true online double-conversion UPS can be installed in a rack or tower configuration with a rotating LED display panel that adjusts accordingly. The unit features replaceable, hot-swappable internal batteries that provide 4 min or more of runtime at full load, with higher backup time available at typical loading conditions. The 5kVA and 6kVA models require 4U of space, while the 8kVA and 10kVA models require 6U of space.
Emerson Network Power
Circle 301
Low-profile power supplies
These three variants to the second generation of Step power supplies are available in 24VDC/0.5A and 12VDC/1A versions, as well as a 12VDC/1.5A model with a shallow-depth design. Designed for applications with low current requirements or those that call for a low profile, the 12VDC/1.5A model measures 43 mm deep, which is
18 mm smaller than the original Step design. Featuring a DIN-rail clip, the product can be mounted either on a rail or in a panel.
Phoenix Contact
Circle 302
Switch-mode power supplies
The Rhino PSE Series product line has been extended to include AC-DC switch-mode power supplies encapsulated in an ultra-compact, low-profile housing. Suitable for space-limited applications, the power supplies can be screw-mounted to a panel or equipment chassis. The products can also be DIN-rail-mounted using an optional DIN-rail-mounting kit. Other features include a universal AC input range of 85V to 264V and output voltage of 5VDC, 12VDC, 15VDC, and 24VDC, as well as ±12VDC and ±15VDC. Available in single- or dual-output models, the single-output models provide a maximum output power range from 15W to 60W, while dual-output models provide 15W and 30W.
Automation Direct
Circle 303
