Analysis software
ETAP 7.0 software features new analysis modules, time-saving capabilities, and online energy management modules integrated to improve the design, analysis, simulation, prediction, optimization, automation, and control of power systems. Product highlights include: one-line diagram, load analyzer, single-phase arc flash, arc flash analyzer, switching management, enhanced libraries, enhanced modules, and enhanced real-time modules.
Operation Technology
Circle 200
Power supplies
Quint SFB industrial-grade power supplies feature a 20A output at 12VDC. According to the company, the unit's Selective Fuse Breaking (SFB) technology allows supplemental branch circuit protection on the DC bus to operate as designed in a control system. Upon sensing a fault condition, the technology delivers a short peak of current (up to six times nominal current) to the faulted load, ensuring the standard branch protection interrupts the circuit as designed. The product also incorporates extra diagnostic feedback elements
Phoenix Contact
Circle 201
Clamp meters
Clamp-Pro meters are available in two versions. The standard 61-744 model features a non-contact voltage indicator (70V to 600VAC), auto/manual ranging, data hold, auto power off, and CAT III-600V rating, while the 61-746 model complements this same feature set with True RMS measurements for users working in harmonic environments. In addition, both versions feature a compact frame, tapered jaws with a hook tip that permits wires to be separated, one-touch buttons for data hold and the non-contact voltage indicator, and an indicator that allows users to know when batteries need replacement.
Ideal Industries
Circle 202
Hybrid motors
HP series hybrid motors combine AC induction motor technology with brushless permanent magnetic motor principles. According to the company, the motors offer savings of up to 80% in energy costs, significant frame size reductions, and weight savings of approximately 50%. Featuring single-phase power ratings of 0.75kW to 2.2kW and 3-phase supply versions of 0.75kW to 22kW in 50/60-Hz applications, the units are available with a built-in drive or as a standalone unit that is compatible with most other manufacturers' drives.
Lafert North America
Circle 203
Design/engineering software
The Autodesk 2010 line of 2D and 3D design and engineering software includes more than 50 products that offer new features and functionality as well as enhanced tools for digital prototyping, BIM, infrastructure modeling, sustainable design, and analysis. The 2010 software for infrastructure modeling includes AutoCAD Map 3D software, Autodesk MapGuide Enterprise software and Autodesk Topobase software. In its digital prototyping solution for manufacturers, the assembly stress analysis and motion simulation tools in Autodesk Inventor Professional 2010 help users simulate and optimize their designs early in the process while a circuit builder tool in AutoCAD Electrical 2010 software enables users to analyze the energy efficiency of circuits. In addition, Autodesk Moldflow 2010 software includes an energy usage indicator.
Autodesk
Circle 204
Occupancy/vacancy sensor
The Radio PowerSavr wireless occupancy/vacancy sensor features the company's XCT technology, which enables the device to detect small motions and distinguish them from background noise or interference that causes false ons/offs. Depending on the overall system configuration, the technology can reduce lighting electricity usage in a given space by 25% to 40%, according to the company. In addition, the product in compatible with the company's Maestro Wireless dimmers and switches, RadioRA dimmers and switches, and GRAFIK Eye QS Wireless control units.
Lutron
Circle 205
freeproductinfo.net/ecm
Protective relay
The EDR-3000 protective relay provides 3-phase and ground overcurrent protection with reclosing capabilities. According to the company, the device offers multiple setting groups, reducing arc flash energy levels and providing zone interlocking to enhance coordination. In addition, the panel-mounted, self-contained unit operates from either AC or direct current DC control power. The product also provides true root mean square (RMS) and fundamental sensing of each phase and ground current.
Eaton
Circle 206
LSZH cable
This line of Low-Smoke Zero-Halogen (LSZH) cable minimizes smoke and harmful gases under combustion, according to the company. Featuring a 300V rating, the cable uses stranded copper conductors for flexibility, features an operating temperature range from -20°C to +75°C, and is available unshielded, overall foil shielded, or in individually foil shielded pairs. In addition, the product meets UL Type CM and CSA Type CMG FT4 and passes the UL VW-1 flame test.
Alpha Wire
Circle 207
Electric motor
Constructed of FC-200 cast iron, the W22 electric motor features a redesigned cooling system that increases airflow while reducing noise level, according to the company. In addition, the motor's terminal box provides increased internal space and easier cable handling and connection. The product's eyebolts also have been repositioned for better handling, and the seal system has been upgraded with increased dust and moisture protection, as well as protection to high-pressure cleaning.
WEG Electric
Circle XXX
LED streetlight
The Golden Dragon oval Plus LED streetlight features oval beam characteristics (80° vertical, 120° horizontal) and an integrated lens, offering energy-efficient lighting with minimal light pollution. Available in various white tones with an efficiency of 90 lm/W in cold white (6,500K color temperature) and 80 lumens per watt in neutral white (5,000 K), the warm white version features a color temperature between 2,700K and 4,500K. The LED is also suitable for standard solder processes.
Osram Opto Semiconductor
Circle XXX
Luminaires
Designed for use in classified hazardous locations, Petrolux III luminaires are available in 50W to 400W. In addition, the indoor/outdoor fixtures can be equipped with a variety of lamps, including metal-halide, high-pressure sodium, compact fluorescent, and induction. Other features include: the company's External Capacitor Module (ECM) option, which extends the life of the ballast system by up to four times over a standard HID fixture, according to the company; and Universal Mount, which offers most mounting configurations in one SKU.
Holophane
Circle 200
Masonry and junction box
MudRunner is a 2-box system comprised of a 4-in. × 10-in. masonry box and a mating 12-in. × 12-in. junction /pull box. The masonry box is cast into concrete slabs along with rigid conduit or flexible PVC tubing called ENT or “smurf tube.” Once the concrete hardens and form boards are removed, the junction box bolts directly to the masonry box to allow wires to be pulled through.
Grady Research
Circle XXX
Power box
The Plastic Power Box is a UL-approved device made of UV-resistant extruded PVC. According to the company, the product is easy to install and supplies power to the gondola with a wide variety of power distribution options. In addition, the product features a separate channel for low-voltage applications, including Cat. 5, phone, and video, and users can modify merchandising displays in minutes.
D&P Custom Lights & Wiring Systems
Circle XXX
Rubber cord
Carol brand Carolprene SOOW/SJOOW rubber portable cords meet temperature ratings from 90°C to 105°C. Featuring an oil-, water-, and sunlight-resistant yellow jacket, the cords are UL-listed, CSA certified, and MSHA-approved for indoor and outdoor use. In addition, they are RoHS certified.
General Cable
Circle XXX
Motor contactors
This line of Fuji electric contactors now includes higher coil voltages. Available in frame sizes of 43 mm, 54 mm, and 67 mm, the SC series components operate with AC coil voltages of 440V to 480V and 500V to 550V, at 60 Hz. The SC series Supermagnet coil contactors include 88-mm, 100-mm, and 115-frame models with AC coil voltages of 380V to 450V and 460V to 575V, at 50/60 Hz. Also available with Supermagnet coils are the Odyssey series contactors in 138-mm and 148-mm frame sizes with AC coil voltage ranges of 380V to 450V and 460V to 575V, at 50/60 Hz.
Automation Direct
Circle XXX
Relay control panels
Measuring 13 in. × 13 in. or 20¼ in. × 34 in., EZ-MAX Plus relay control panels are designed for smaller applications that don't require field-configuration or advanced networking capabilities. Available in 4/8-circuit or 16/24-circuit models, the panels feature the Visual Programmer 4.0 offline editor as well as a large LCD screen on the face of the enclosure that includes oversized buttons and speed programming. In addition, the product replaces multiple SKUs with a single SKU. The panels also combine modular relay cards and a built-in astronomical time clock (ATC) that is used in place of separate time clocks, cabinets, terminal blocks and contactors. Standard programming configurations for occupancy sensors and photocells as well as a built-in ATC with 101 major cities and states are included in the system.
Leviton
Circle XXX
Gear motors
VWDIR104 parallel shaft AC gear motors have been added to the company's line of Von Weise drop-in replacement gear motors. Available with either 1/10-hp or 1/15-hp 115/230V, 60/50Hz permanent split capacitor electric motors, the unit's integral gear reducers feature hardened steel helical and spur gearing with ratios ranging from 108-to-1 to 266-to-1. Corresponding fixed output speeds are from 15 rpm to 6 rpm with continuous torque ratings from 350 in.-lb to 500 in.-lb. In addition, the product features built-in face mounting that is compatible with Genesis mounts and overhung load capability up to 400 lb.
Bison Gear & Engineering
Circle XXX
LED light panel
This LED light panel is constructed of optic acrylic plates and features CNC machined v-cut light distribution grids on its back. With a thickness of 0.88 mm, the panel offers an input voltage of 12VDC, a color temperature of 3,500K or 5,300K, an operating temperature of -40°C to +35°C, and a 70,000-hr life span, according to the company. Dimmable, the unit is available in standard as well as custom shapes and sizes.
Fawoo Canada
Circle XXX
LED luminaire
The Arrow hart line of commercial specification-grade LED luminaires now includes four additional models. The LNL1 and LNL4 Series feature a choice of vertical or horizontal louvered faceplate, while the LNL2 and LNL3 Series both feature a vertical scoop faceplate. In addition, the LNL2 is equipped with an illuminated on/off push-button switch for instant light activation. All models include a polycarbonate lens, die-cast aluminum faceplate, and operate on a standard 12Vpower supply. Featuring a 20,000-hr rating, the LNL1, LNL3, and LNL4 models are available in white, amber and red. The LNL2 is available in white. Faceplate color choices include white, black, and brushed-nickel for the LNL1, LNL3, and LNL4, and white for the LNL2.
Cooper Wiring Devices
Circle 204
