Industrial connectivity system
The Arrow Hart brand LynxPower industrial connectivity system features four application packages. The SoftPower application is designed for industrial applications in which electrical connections are exposed to physical abuse. The Mini-Line cordsets and receptacles allow users to select from a variety of standard and custom configurations as well as plex boxes and accessories. They are designed for industrial automation applications in which power or signal connections are exposed to long-term physical stresses and subjected to liquids and/or oils. The Micro-Mini & Pico-Line package is suitable for use in low-amperage AC or DC control systems and is designed for sensor and control equipment used in many manufacturing environments. The Industrial Network package is for data and signal transfer in industrial environments. In addition, it can be used with Ethernet, DeviceNet, Profibus, SDS, and Seriplex systems.
Cooper Wiring Devices
Circle 200
Clamp meter
The EX840 1,000A CAT IV clamp meter features a built-in infrared thermometer. The meter's functions include AC-DC voltage, resistance, capacitance, frequency, diode, and continuity. In addition, the product captures true rms current and voltage measurements, and peak hold captures inrush currents and transients. Other features include a bright 4-digit 4,000 count backlit display, a 1.7-in. jaw opening for conductors up to 750MCM or two 500MCM, an auto power-off feature, data hold and min/max, and autoranging with a manual range button. The device also includes an 8-piece test lead set, 9V battery, Type K probe, and belt holster.
Extech Instruments
Circle 202
Photovoltaic fuse
The PV Fuse amperage now covers 1A through 15A for protecting solar panel photovoltaic (PV) cell strings. The fuse provides low-level fault protection that can clear faults as low as 1.3 × In at 1,000VDC. Designed for 4-in., 5-in., and 6-in. solar cell-based panels as well as thin-film based panels, the device is designed with a maximum 1,000VDC operating voltage based on typical solar panel systems with L/R of 1 msec and below. In addition, the product is available in the globally accepted 10-mm × 38-mm dimension with all amp ratings available with standard ferrule, bolt, and PCB-mount options.
Cooper Bussmann
Circle 204
Lighting controllers
This family of lighting control products is compliant with the Buy American provisions of the American Reconstruction and Reinvestment Act of 2009 (ARRA). Comprised of occupancy sensors, relay panels, daylighting, and plug load controls, the products were selected to meet the growing demand on ARRA-funded public works projects for products that advance energy efficiency in new and existing buildings.
WattStopper
Circle 201
LED luminaire
The Series 6000 LED cove light is a modular-, cove-, and soffit-mounted non-glare, high-brightness LED lighting system that projects shadow-free brightness into interior spaces, according to the company. Suitable for new or retrofit applications, this line voltage system features an integral LED driver and power supplies, making it a direct replacement for existing fluorescent cove lighting.
Tempo
Circle 203
Residential cable
The Carol brand Sheer Wire Residential and Pro AV cabling product line now includes cables for use with Crestron, AMX, Lutron, Vantage, and Elan home systems. In addition, the series includes indoor/outdoor high-resolution speaker cables and 25 AWG solid and stranded RGB (plenum and non-plenum).
General Cable
Circle 205
freeproductinfo.net/ecm
Power management software
PowerLogic ION Enterprise power management software has been enhanced to include a new Web Reporter module that allows users to quickly create, customize, and schedule reports. New reporting functions include period-over-period or by-shift comparisons, trending and tables, alarm and events history, and system configuration. In addition, the product provides a 100-msec time-stamped report, using circuit breaker activity, to aid power quality problem diagnosis and support evasive action control. New display formats include histograms, pie charts, tables, and trends. This latest release enhances report generation flexibility by exporting the reports to a PDF or Word format, in addition to the existing Excel, HTML, and XML formats.
Schneider Electric
Circle 206
LED luminaire
The WWL20-24X2W-XPW-001W Wall-pak luminaire runs on a range of voltages from 100VAC to 277VAC, consuming 56W of power. Designed for mounting on walls, ceilings, or floors indoors and outdoors, the wide-beam and weatherproof unit is constructed of die-cast aluminum and a high-impact, heat-resistant polycarbonate lens. In addition, the luminaire emits a wide-focused circular beam of light approximately 85° that spreads 157° vertically and 38° horizontally.
Ledtronics
Circle 207
Panel management software
eye:d electrical panel management software is a Web-based program that allows users to keep up-to-date information on electrical loads throughout a facility. Highlights include the ability to track measured loads versus connected loads and track verified and non-verified loads. In addition, users can print customized electrical panel directories, panel schedules, and power load summaries.
SR2G
Circle 208
Electrical design software
SEE Electrical software is available in three versions. The basic level provides numerous basic CAD functionality. The standard level helps create and manage electrical diagrams while the advanced level includes functions such as PLC input/output management and automatic plan generation. The software also features two trade-specific modules: Cabinet layout helps users design electrical cabinets, and house installation supports the layout of electrical equipment on floor plans.
IGE+XAO Group
Circle 209
BACnet interface module
The ECS BACnet Interface Module enables the integration of ECS with any BACnet-compatible building automation system, permitting ECS to share real-time data with a building automation system, such as lighting status, lighting levels, occupancy status, and energy usage. Product highlights include enabling the building automation system to control switching and dimming functions and controlling load shedding by providing information about the amount of lighting load that can be reduced and where it is located.
Encelium Technologies
Circle 210
Thermal imagers
The T300 and B300 thermal imagers feature a 320 pixel × 240 pixel detector. Designed for electrical and mechanical inspections, the T300 matches 2% thermal accuracy, 30-Hz frame rate, and less than 0.05°C thermal sensitivity with a temperature measurement range of -20°C to 650°C and an optional range reaching 1,200°C. The B300 infrared camera is tailored for building, weatherization, and restoration audits. In addition, it features a temperature range of -20°C to 120°C as well as moisture and insulation alarms. Both models feature a lens that rotates vertically up to 120°.
Flir Systems
Circle 211
Circuit breakers
This latest addition to the company's family of UL508 manual motor controllers features a reinforced housing, box and ring tongue terminals, and a clear cover. The circuit breakers are offered in six trip curves and in ampere ratings from 0.3A to 60A with voltage ratings of 480Y/277VAC and 28VDC to 80VDC. Designed for DIN-rail mounting, the product measures 17.5 mm wide per pole and is available in one, two, and three poles.
Altech
Circle 212
HID luminaire
This luminaire is an upgrade to the company's electronic HID (E-HID) product line. Delivering more than 100 lumens per watt, the luminaire features a ballast housing constructed of corrosion-resistant galvanized steel. According to the company, the product can be installed easily at existing mounting points, and fits any voltage between 200V and 300V. In addition, the fixture features pulse-start metal-halide technology for stable light output across the entire operating range.
Hubbell Industrial Lighting
Circle 213
DDC controls
Metalaire DDC controls ship from the factory addressed and ready to install. Offered in BACnet and LON options, both models provide VAV controls that can easily be integrated into the building operating system.
Metal Industries
Circle 214
Energy logging system
The Hobo Measurement & Verification System portable energy logging system measures, analyzes, and documents building energy performance. Housed in a rugged carrying case, the self-contained system features prewired sensors and magnetic mounting feet. Available in single-phase and 3-phase versions, both models include a 4-channel data logger, energy sensors, software, cables, and accessories.
Onset
Circle 215
Remote power panel
The Cyberex high-power remote power panel (RPP) with rack-like form factor is designed for integration into standard rack lineups. Available in 225A and 400A configurations and in voltages up to 415V, the RPP distributes a higher voltage and amperage to put more kilowatts into the white space, according to the company. It also requires a smaller footprint because the transformer can be placed elsewhere.
Thomas & Betts
Circle 216
Automation controller
The Productivity3000 programmable automation controller combines features and capabilities of a PC-based control system with that of a typical programmable logic controller (PLC). The controller is a modular, rack-based system of up to 116,000 I/O points with local, expansion, and remote I/O bases and a full lineup of discrete, analog and specialty I/O modules. The CPU features 50Mb memory, fast scan times, and seven communication ports. Two power supplies (AC- and DC-powered) are available; both provide isolated 24VDC, 5VDC, and 3.3VDC to the product's bases. I/O bases are available in 3-, 5-, 8-, and 11-slot models.
Automation Direct
Circle 217
