Ecmweb 5530 Ps
Product Spotlight: Focus on Raceways and Wireways
April 16, 2013
This month, EC&M magazine spotlights raceways and wireways from Starline, Calbrite, Electri-Flex, and NTE
Raceway
Plug-In Raceway provides on-demand power in a scalable format. Offering the ability to add or relocate plug-in modules anywhere on the raceway, the product features a smooth aluminum finish and requires nearly one-third less installation time than the leading competitor, according to the company. Designed to replace traditional wire and conduit runs with copper bus bars that are pre-installed into the raceway sections, the raceway allows users to simply snap any number of pre-assembled plug-in modules into place on the raceway backplane for an instant connection — without having to interrupt power. Available in white or metallic silver with custom colors offered on request, the product comes in 20A, 40A, or 60A bussing; 120/208VAC or 277/480VAC; 3 phase.
Starline
Circle 300
Stainless steel conduit
This threaded and non-threaded IMC is manufactured in Type 304 and 316 stainless steel to meet the requirements of stringent sanitary environments. The threaded conduit can be used with compression or standard threaded couplings, while the non-threaded version can be easily connected with the use of the company’s NEMA 4X-approved stainless steel compression connectors. Offered in standard 10-ft lengths in ½-in., ¾-in., 1-in., 1½-in., and 2-in. trade sizes, custom lengths are available up to 20 ft.
Calbrite
Circle 301
Flexible conduit
Types ATLA and ZHLA flexible conduit are now offered in colored options. Type ATLA is a flexible jacketed metallic conduit covered in a flame-retardant PVC jacketing designed for extreme hot or cold environments. The flexible inner core is identical to Type LA and is UL-listed and CSA certified. Temperature ranges include: -55°C to 105°C Air/60°C Wet/70°C Oil (UL-listed); -50°C to 105°C Dry/75°C Oil (CSA-certified). Type ZHLA is also a flexible jacketed metallic conduit offering zero-halogen, low smoke, low flame spread jacketing qualities.
Electri-Flex
Circle 302
Split loom
Designed to hold, protect, and conceal cables, harnesses, hoses, and wires, this colored split loom is quick and easy to install, with the slit automatically closing after installation. Made of a durable, flexible polyethylene construction, the product is offered in orange, green, red, and yellow colors with diameters of ¼ in., 3/8 in., ½ in., 5/8 in.,
¾ in., and 1 in. Available lengths include 5 ft, 10 ft, and 100 ft.
NTE
Circle 303
