maki_shmaki/iStock/Thinkstock
656497862
Combustibles, Part 4
May 15, 2018
Ways to prevent possible ignition of items when welding
Ignition sources are present in nearly any industrial or commercial facility. You can’t eliminate them, but you can keep them away from combustibles. Suppose you have a work order that calls for repairing a mounting bracket in a storage area for bales of paper. Welding is required. How can you prevent the ignition of that paper?
Possible solutions include:
  • Unbolt the bracket, weld it in the shop, and return to bolt the bracket back in place. This assumes the bracket can be unbolted.
  • Move the paper bales out of that area or at least move them far enough away to create a safe work area. This could require much time and effort.
  • Move a few bales away, and erect a spark-proof barrier of sufficient height and width to prevent sparks from reaching the bales.
  • Question the work order. Is the bracket really needed? Why is welding required? Is there another repair method (e.g., bolting or epoxies) that’s safer for this area?
