Ecmweb 7013 1 22 15wwhlarge
What’s Wrong Here? Hint: Deep in Thought
Jan. 22, 2015
Hint: Deep in thought
This box is simply set too far back into the wall. Section 314.20 tells us that boxes installed in walls made of concrete, tile, plaster, or other non-combustible material must be installed so that they will not be set back from the surface more than ¼ inch. Although it might be a little hard for you to see, when I zoomed in on this photo, this box appears to be set back at least an inch or so from the wall surface. That is not permitted. Where boxes are installed in combustible walls, they may not be set back at all. In combustible walls, the box must be installed flush with the finished surface or project beyond it.
The installation in this photo does not appear to be completed yet. Some of the wires are not connected, and the cover or fixture has not yet been installed. I can only assume the installer will “do the right thing” and complete this installation so that it would be Code compliant. An extension box could be installed on top of the existing box in order to have the box not set too far back. According to Sec. 314.21, any wall gaps around the box or extension must be repaired so that there are no open spaces greater than 1/8 in.
Russ LeBlanc | Owner
