Whats Wrong Here?
Whats Wrong Here?
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn't identify? Here's your chance to moonlight as an electrical inspector and second-guess someone else's work from the safety of your living room or office. Joe, who has a knack for finding shoddy electrical work, did the dirty work and found this mess. Now it's your turn to identify the violation.
"Check out this splice box we found in a residential attic," says Richard Tanner of Mr. Electric in south Alabama. "Yes, the installer placed PVC couplings over split bolts and filled the void with caulk! Hey, at least they used Romex connectors."
As per 110.14(B), "Conductors shall be spliced or joined with splicing devices identified for the use or by brazing, welding, or soldering with a fusible metal or alloy. Soldered splices shall first be spliced or joined so as to be mechanically and electrically secure without solder and then be soldered. All splices and joints and the free ends of conductors shall be covered with an insulation equivalent to that of the conductors or with an insulating device identified for the purpose. Wire connectors or splicing means installed on conductors for direct burial shall be listed for such use."
It's clear these homemade splice units are not identified or listed for electrical use.
> Try Another Quiz
Hide comments
Comments
Plain text
  • No HTML tags allowed.
Publish
