Know Your Definitions
Sept. 4, 2014
Article 100 lists definitions that are essential to proper application of the NEC.
The _____ of any system is the ratio of the maximum demand of a system, or part of a system, to the total connected load of a system.
a) load
b) demand factor
c) minimum load
d) calculated factor
The correct answer is: b) demand factor
Article 100 lists definitions that are essential to proper application of the NEC. The definition shown for demand factor reads as follows: "The ratio of the maximum demand of a system, or part of a system, to the total connected load of a system or the part of the system under consideration."
Mike Holt
