Copyright Bill Ingalls/NASA via Getty Images
Ecmweb 6575 Spacecenter595
NASA Awards Construction Contract at Kennedy Space Center
Aug. 15, 2014
The maximum value of this firm fixed-price contract is $64,823,000, including base work and five awarded options.
NASA has awarded a two-year contract to Hensel Phelps Construction Co. of Orlando to build a new multi-story headquarters building at the agency's Kennedy Space Center in Florida.
The maximum value of this firm fixed-price contract is $64,823,000, including base work and five awarded options. The contract award began last month.
The new headquarters building is the cornerstone for Kennedy’s central campus consolidation. The campus construction will enable demolition of approximately 900,000 square feet of buildings and supporting infrastructure in what is known as Kennedy Industrial Area, while rebuilding only about 450,000 square feet. Kennedy will save an estimated $400 million during the next 40 years because of the 50 percent reduction in square footage and the lower operation and maintenance costs associated with the new energy-efficient facilities.
Hensel Phelps will provide all the construction and installation of required civil, structural, electrical, plumbing, environmental, mechanical, fire suppression, and communication infrastructure. Under the five options, the company will remove U-Shaped Pre-Cast Panel and Pre-Cast, add additional landscaping, add seven dual station electric vehicle battery charge stations in parking areas, provide LED light fixtures instead of fluorescent and compact light fixtures, and upgrade the 800kW emergency generator environmental rating from tier 2 to tier 4 and provide future utility system interconnection capability.
Strut Comparison Chart
NECA Manual of Labor Rates Chart
See how Champion Fiberglass compares to PVC, GRC and PVC-coated steel in installation.
