Product News
Nov. 1, 2008
Power management software PowerAlert software features three components for power management. PowerAlert Network Management System lets network managers monitor and control up to 250 UPS systems and PDUs through a single interface, while PowerAlert Local allows users to monitor and control UPS systems connected to a host computer through a USB or serial cable. PowerAlert Network Shutdown Agent lets
PowerAlert software features three components for power management. PowerAlert Network Management System lets network managers monitor and control up to 250 UPS systems and PDUs through a single interface, while PowerAlert Local allows users to monitor and control UPS systems connected to a host computer through a USB or serial cable. PowerAlert Network Shutdown Agent lets the host computer monitor a designated PowerAlert Local client or SNMPWEBCARD accessory over the network. When a selected power event is detected, the host computer automatically hibernates or shuts down.
Tripp Lite
Circle 150
TVSS
The Square D Surgelogic high-resistance ground (HRG) EMA surge protective device (SPD) is a modular parallel transient voltage surge suppressor (TVSS) that provides protection from transients referenced phase-to-phase and phase-to-ground. According to the company, each surge suppression mode is individually fused and uses circuitry with thermal cutouts to isolate the SPD and ensure shutdown in the event of MOV damage during severe outages, even when operated on high-fault current power systems.
Schneider Electric
Circle 151
freeproductinfo.net/ecm
Single-phase UPS
The Sinergy S II Series single-phase UPS features online double-conversion technology. Available in a rack/tower configuration, the UPS is offered in a low-voltage (120V) model (700VA, 1kVA, 1.5kVA, 2kVA, and 3kVA) as well as two high-voltage (200V and 240V) versions (2kVA and 3kVA). All models operate at 50 Hz or 60 Hz and feature automatic bypass, controllable receptacles, and a remote power-off adapter. In addition, the product has hot-swappable internal batteries that can be changed without shutting down the unit. Other product features include front panel LEDs, an audible warning that signals at 4-sec intervals, and extended run time capability that allows backup power protection for up to 4 hr.
Chloride
Circle 152
