Avoiding Landmine Repairs, Part 12
For each major piece of equipment, develop quick checklists to help you discover issues before walking away from a repair.
Sept. 24, 2013
You look foolish if equipment malfunctions again an hour after you repaired it. Maybe you didn't do anything wrong that set a landmine for another failure to occur. But if you fixed only what the issue that precipitated the trouble call, you can easily leave a landmine for yourself.
The adage, "Where there's smoke, there's fire" tends to prove itself in the world of industrial equipment repairs.
A classic mistake that sometimes actually results in fire is simply replacing a blown fuse without determining why it blew. A fuse isn't just some inadvertent weak link that eventually goes past its freshness date and opens. A fuse opens because of a problem. Yes, sometimes a transient problem can cause a fuse to blow, so positively identifying the problem isn't always possible. But you need to rule out other causes before replacing the fuse.
