Code Quiz
Excluding exceptions, which one of the following locations does not require GFCI protection for 15A and 20A, 125V single-phase receptacles?
Q. Excluding exceptions, which one of the following locations does not require GFCI protection for 15A and 20A, 125V single-phase receptacles?
  1. bathroom (anywhere)
  2. within 6 feet of a sink in a commercial or industrial facility
  3. electric drinking fountain
  4. outdoors on a commercial building
  5. cord-and-plug connected vending machines
  6. outdoors and in or on a floating building or structure within the electrical datum plane
  7. within 20 feet of a decorative fountain
  8. in aircraft hangars where electric diagnostic equipment, electrical hand tools or portable lighting equipment are used
  9. in commercial garages where electric diagnostic equipment, electrical hand tools or portable lighting equipment are used
  10. dwelling unit attics, in accordance with 210.63
Answer: J
The 2008 NEC added several new locations to the growing list of places where GFCI protection is required (B, C, and D in the list above). There were also revisions to existing sections of the Code that already required GFCI protection (D above). It is important for you to check all of the affected sections of the Code by referring to the index of the 2008 NEC and noting the following list of references: 100 Definitions, 210.8, 210.63, 422.51, 422.52, 511.12, 513.12, 680.58, and 682.15.
