Ecmweb 2546 1 07 08
Outdoor luminaire
Jan. 7, 2008
The PathMaster composite LED bollard is an outdoor architectural fixture ETL listed to UL 1598 and 1838 standards
The PathMaster composite LED bollard is an outdoor architectural fixture ETL listed to UL 1598 and 1838 standards. Designed to provide energy-efficient illumination for normal and emergency use, each light engine uses three white LEDs for illumination and can be applied from one to all four sides of the bollard. In addition, the bollard can be affixed by an anchor base, lag bolts, or direct burial. Fabricated from fiberglass-reinforced polymers, the product’s exposed hardware is stainless steel, and the light engines are constructed of die cast aluminum. Standard finishes include black, bronze, and white. Custom finishes are also available.
Chloride, a Genlyte co.
For more information, visit www.chloridesys.com.
