Reporting software
ASCO PowerQuest Test Reports software helps facilities comply with NFPA1, NEC2, and JCAHO3 reporting requirements for on-site power system testing, operation, load profiling, and peak load shaving
July 22, 2011
ASCO PowerQuest Test Reports software helps facilities comply with NFPA1, NEC2, and JCAHO3 reporting requirements for on-site power system testing, operation, load profiling, and peak load shaving. According to the company, the software automates the data logging required to comply with NFPA 99 and 110 for exercising emergency power systems, NEC 220.87 for documenting actual on-site power demand load, and JCAHO requirements for helping ensure reliable power for life safety loads. The product’s data format parallels the requirements of reporting codes and standards, and includes monthly testing, peak load shaving, frequency and test length, date and time of test, equivalent loads (load banks), load run/banks for diesel-powered emergency power systems only, and cold starts.
Emerson Network Power
For more information, visit www.EmersonNetworkPower.com.
