EV charging station
This ETL-certified 20A/240V Level 2 pedestal-mounted electric vehicle (EV) charging station is available in single and dual configurations
This ETL-certified 20A/240V Level 2 pedestal-mounted electric vehicle (EV) charging station is available in single and dual configurations. The charging station is fixed on an anod
ized aluminum Vista Architectural column that is fully weatherproof with a NEMA 3R rating, allowing it to be installed outdoors or indoors in covered parking/charging areas. Compatible with all plug-in EVs, the product provides a full charge in 3 hr to 6 hr, according to the company. Safety features include built-in GFCI protection with a self-test feature, ground continuity monitoring to ensure proper grounding, and communication with the vehicle to confirm electrical connections prior to charging. The unit also includes an auto reset feature that allows the charger to re-try after a minor electrical fault.
Legrand/Pass & Seymour
For more information, visit www.legrand.com.
