Ecmweb 6987 Milwaukee Tool M12 Compact Vacuum
Compact vacuum
Jan. 12, 2015
29 min. of continuous runtime on single charge 1¼-in. universal connection to fit most standard vacuum attachments Reusable 42-pleat filter
The M12 Compact Vacuum uses a high-efficiency motor and the company’s Redlithium battery technology to deliver up 29 min. of continuous run time on a single charge. The vacuum comes with three accessories: A crevice tool for accessing tight spots, a utility nozzle for larger surface area clean up, and an extension wand. The vacuum also has a 1¼-in. universal connection to fit most standard vacuum attachments. Features include a clear viewing window allows for easy identification of the capacity level in the 20 oz. canister and a reusable 42-pleat filter.
Milwaukee Tool
