Ecmweb 7045 Nora Lighting 4 Downlight Trims
Downlight trims
Jan. 29, 2015
Constructed of die-cast aluminum Designed for use with standard round housings Offered in three square flange styles with sharp edges
These 4-in. die-cast aluminum square trims are for the company’s LED Diamond II 90+ Retrofit Series. Designed for use with standard round housings, the trims are available in three square flange styles with sharp edges for a contemporary appearance. The series includes a square flange with round reflector, a square flange with square 2-in. pinhole, and a square flange with square 2.75-in. regressed opening.
Nora Lighting
