Ecmweb 7134 Thomas Research Products Pled96w Hv Series Drivers
LED drivers
Feb. 23, 2015
96W output Eliminate need for step-down transformers inside luminaires Available in constant-current, dimmable, and constant-voltage versions
PLED96W-HV Series drivers with 96W output eliminate the need for step-down transformers inside luminaires. Providing flicker-free output, the drivers are designed for high-wattage indoor or outdoor LED luminaire applications. Available in constant-current, dimmable, and constant-voltage versions, the products work on any mains from 277-480VAC, making them suitable for 347V applications. Other features include Black Magic Thermal Advantage aluminum enclosures. In addition, they are IP66-rated for dry and damp locations.
Thomas Research Products/Norlux
