Ecmweb 8562 Hazard
OSHA Finds Multiple Electrical Hazards at Kansas Battery Manufacturer
May 11, 2016
The U.S. Department of Labor's Occupational Safety and Health Administration issued one willful, and 10 serious safety and health violations to Exide Technologies.
As they investigated unsafe working conditions at a Salina, Kan., battery manufacturer, federal investigators initiated a second safety inspection after the company reported an unguarded machine partially amputated a 32-year-old worker's left middle finger.
On April 26, the U.S. Department of Labor's Occupational Safety and Health Administration issued one willful, and 10 serious safety and health violations to Exide Technologies based on the Oct. 27 complaint and Dec. 3, 2015, injury inspections. OSHA found workers exposed to electrical and machine hazards. The agency also issued a hazard alert letter to the plant for failing to implement a heat-stress program. OSHA proposed total penalties of $127,300.
OSHA cited the company for:
  • Using electrical cable trays and equipment found deteriorating from exposure to sulfuric acid vapors.
  • Allowing acid and water to accumulate on floors causing holes, slip and trip hazards.
  • Impeding exit paths.
  • Failing to develop a permit-required confined space program.
  • Not training and monitoring workers in confined space.
  • Not labeling hazardous chemical containers.
  • Failing to train workers about hazardous chemicals in use.
"Exide Technologies is exposing workers to dangerous electrical and machine hazards that can cause devastating and life-changing injuries like the one this worker suffered," said Judy Freeman, OSHA's area director in Wichita. "While working as a strip caster, this man joined 65 other Kansas workers who, the Bureau of Labor Statistics, reports suffered preventable, workplace amputation injuries in 2015. Exide needs to clean up its act and take immediate action to fix these hazards."
Inspectors found the amputation injury occurred when the strip caster's left hand was caught in the unguarded belts, pulleys and gears of a lead chopping machine at the facility.
View citations from Oct. 27 health, safety and Dec. 3 safety inspections.
Based in Milton, Ga., Exide focuses on smart battery development and advanced materials and process design at research facilities in the U.S., Germany, Italy and Spain. The company employs about 620 workers at the Salina facility and 5,000 globally.
Strut Comparison Chart
