Rosslyn, Va.-based National Electrical Manufacturers Association (NEMA has published revisions to two standards within the ANSI C18 series of standards for batteries:
- ANSI C18.1M, Part 2-2011, "American National Standard for Portable Primary Cells and Batteries with Aqueous Electrolyte—Safety Standard"
- ANSI C18.3M, Part 2-2011, "American National Standard for Portable Lithium Primary Cells and Batteries—Safety Standard"
Each standard specifies tests and requirements for specific types of batteries to ensure their safe operation under normal use and reasonably foreseeable misuse. In ANSI C18.3M, Part 2, the committee highlighted the importance of designing battery compartments with mechanical retention devices to prevent swallowing and ingestion of batteries by children. Annex A, though informative, provides guidance for device designers when considering the proper use of batteries in electrical devices.
The contents and scope of ANSI C18.1M, Part 2 may be viewed, or a hardcopy or electronic copy purchased for $78, by visiting www.nema.org/stds/c18-1m2.cfm. For ANSI C18.3M, Part 2, also $78, go to www.nema.org/stds/c18-3m2.cfm. Both standards may also be purchased by contacting IHS at 800-854-7179 (within the United States.), 303-397-7956 (international), 303-397-2740 (fax), or global.ihs.com.
