Damper reduces the spread of fire and smoke in HVAC systems
The Combination Fire/Smoke Dampers combine two dampers in one. The two-position device is tested to 5,000 cycles, intended to prevent the spread of fire (UL 1-1/2-hour fire rating), as well as smoke (UL Class II 350 F leakage rating). Johnson Controls
