Industrial pressure gauge transmits data
The Series 700 Plus Pressure Transmitter Gauge provides an easy-to-read 4-inch dial and an integral pressure transmitter. This combination enables the user to obtain a local indication of pressure, as well as a process, current or voltage, signal for remote indication, control or data acquisition. The transmitter gauge is supplied with either 1/4-inch or 1/2-inch NPT connections and attached electrical
The Series 700 Plus Pressure Transmitter Gauge provides an easy-to-read 4-inch dial and an integral pressure transmitter. This combination enables the user to obtain a local indication of pressure, as well as a process, current or voltage, signal for remote indication, control or data acquisition. The transmitter gauge is supplied with either 1/4-inch or 1/2-inch NPT connections and attached electrical cable. Vespo
