NEW PRODUCTS
Dual-strobe device provides two stages of notification The SpectrAlert dual-strobe series provides two stages of notification for life safety for security, evacuation, tornado alerts and other emergencies. The series is UL 1638 listed and can be customized. Housings are available in red or white; strobes in a variety of colors. System SensorCircle 252 on Reader Service Card Connector provides reliable
Connector provides reliable interconnections
The Series SQS connector provides reliable interconnections for wire-to-inflator circuits. The connector design is based on VDA standard inflator specifications. The two-position connectors are rated 3A AC/DC (16V AC/DC) on a 3.1 mm (0.122-in.) pitch. J.S.T. Corp.
Circle 256 on Reader Service Card
Digging equipment attachment improves trenching work
The Ditch Witch Model H514 hydraulically traversing digging attachment for the Model 5700 trencher improves the trencher's reliability and productivity. A sealed Eaton motor and bearings and head shaft eliminate the need to pre-load the bearings. The Charles Machines Works
Circle 257 on Reader Service Card
Products take the sting out of summer
This range of insecticides include the Bee Blast wasp and hornet killer, with a high-output 22-ft jet blast that soaks insects and knocks them out of their nests. The fast-acting formula kills on contact, yet is plastic safe. Also offered are the Wasp & Hornet Plus insecticide, Double Strength insect repellent and the SunSwipe sunscreen towelette. CRC Industries
Circle 254 on Reader Service Card
Transfer system provides easy generator integration
This soft load transfer system uses proprietary technology to provide a “virtually seamless” integration between on-site generators and the utility grid. Serving as an interconnect device, the system is especially advantageous in distributed generation applications, because it creates a gradual power shift as loads are switched from one power source to another, thereby facilitating peak shaving and sharing, net metering and power resale to the utility. ASCO
Circle 253 on Reader Service Card
Fiber-optic power meter tests any FO network
The DM300 high-performance fiber-optic power meter comes in a portable handheld package. The instrument can be used to measure optical power or loss in any fiber-optic network or for testing fiber-optic components. The meter can be ordered with either of two detectors, silicon or germanium, with measurement ranges in wavelength from 400nm to 1,000nm or 850nm to 1,650nm, respectively. Fotec
Circle 261 on Reader Service Card
Thermometer measures surface temperature
The Model 4252F thermometer measures non-contact surface temperature with a 1-deg resolution. The fixed emissivity of 0.95 accommodates 90% of surface applications. Features include large LCD display, narrow field of view and automatic data hold. The instrument is best for measuring the temperature of objects that are difficult to reach or unsafe to touch. It comes complete with a 9V battery. Extech Instruments
Circle 260 on Reader Service Card
Fiberglass safety enclosures deflect arcs and sparks
The TRG series of fiberglass increased safety enclosures provide explosion protection by preventing the possibility of excessive heat and the occurrence of an arc or spark from the terminal blocks installed. The enclosures offer protection by maintaining secure connections. Adalet
Circle 278 on Reader Service Card
Floodlight fixtures are for hazardous areas
This full line of floodlights for industrial applications is suitable for hazardous and non-hazardous areas. The floodlights come in a variety of sizes, wattages and mounting styles to fit all industrial lighting needs. They come in three distinct lines. Cooper/Crouse Hinds
Circle 258 on Reader Service Card
Recessed downlighting fixtures look sharp
The Varanti and Focus adjustable and fixed recessed downlights with coordinating trims provide illumination for a range of upscale residential environments. The Varanti is best suited for accenting architectural features; the Focus is best for recessed indoor lighting. Ardee Lighting
Circle 251 on Reader Service Card
Pendant-style switches weather the elements
Offered in two-, four- and six-button models featuring one or two speeds, these pendant pushbutton switches cover a wide range of industrial applications. The switches are especially effective in wet locations, due to their weather-tight neoprene enclosures. McGill
Circle 255 on Reader Service Card
Channel framing comes in every strut style
A complete line of Eristrut channel framing is available in every strut style for almost every application, including half slot, full slot, punched, back-to-back and knockout. The product is available in several finishes. Also offered are clamps, hangers and fittings to support from strut. Erico
Circle 294 on Reader Service Card
Software program allows remote job tracking
The Jobclock is a hardware and software package that allows remote job time and attendance tracking. The heart of the Jobclock system is a small, construction-grade time clock that can be affixed and left at the job site. Because it is weatherproof, tamper-proof and battery-powered, it is entirely self-contained. Employees clock in and out via miniature buttons designed to be carried on their keychains. Exaktime Inc
Circle 296 on Reader Service Card
Software makes safety signs for the job site
The MaxiSoft MaxiSigns99 safety and facility sign-making programs work on all versions of Windows. The software makes it easy and inexpensive to design and print safety and facility signs and tags in-house using a PC, ink jet or laser printer and new UV-protective lamination films. It allows any manufacturing facility, hospital, school, lab or job site to make OSHA and ANSI-compliant safety signs. K-Sun
Circle 279 on Reader Service Card
Wire mesh cable tray can be cut to feet and inches
The Ameri-Tray wire mesh cable tray system is manufactured to feet and inch dimensions, solving the problem of converting tray requirements from metric. The manufacturer said it's a problem contractors who install metric cable tray constantly confront. Triangle Electrical Products
Circle 295 on Reader Service Card
UPS line provides total power protection
The Pinnacle family of double conversion UPS systems is designed to provide total power protection for communication networks. The UPS provides clean, reliable power for various applications using Digital Signal Processing (DSP) technology, offering pure, sine wave power to critical equipment with zero transfer time. Alpha Technologies
Circle 297 on Reader Service Card
