EDITOR'S CHOICE
Non-metallic emergency lighting system usable in corrosive areas The N2LS Series non-metallic emergency lighting system is designed for highly corrosive and hazardous locations. NEMA 3R (raintight) rated, it offers the versatility of remote or direct mounted fixtures. Appleton, EGS Electrical GroupCircle 261 on Reader Service Card Fiber-optic system offers a future-proof solution The FiberSmart fiber-optic
The FiberSmart fiber-optic product line suits a variety of applications, including fiber to the desktop, throughout a building, outside or for an entire campus. Standard wall- and rack-mount enclosures can be field-configured. Pass & Seymour/Legrand
Circle 263 on Reader Service Card
Towelette cleans delicate fiber-optic cables
Type FO is a pre-saturated towelette for cleaning delicate fiber-optic cables during splicing to maximize light transmission performance.The towelette removes dust, oils and contaminants, while leaving no residue. American Polywater Corp.
Circle 264 on Reader Service Card
Multifunction meter is designed for testing three-phase motors
The Model 61-521 Phase and Motor Rotation Meter is designed for testing motors and motor starters ranging up to 600V. The meter provides three troubleshooting functions in a single unit — indicating three-phase sequence and motor rotation and checking for open phases. Identifying correct phase sequence and motor rotation is critical to ensuring fast, simple and trouble-free service of three-phase motors. It also prevents damage to costly motor components due to improper wiring. Color-coded wired leads with alligator clips make the instrument easy to use. Ideal Industries Inc.
Circle 246 on Reader Service Card
Web-enabled power meters extend reach across factory floor
The manufacturer has added the Modbus master communications capability to its Web-enabled ION 7500 and ION 7600 energy and power- quality meters. The feature extends the reach of the meters' monitoring and control capabilities across a factory floor, within a utility substation or throughout a commercial facility by integrating a network of Modbus-compatible devices. The meter reads physical parameters from a variety of Modbus slave devices such as breakers, HVAC sensors or other utility meters. Power Measurement
Circle 265 on Reader Service Card
