Wood boring system increases efficiency
Nov. 1, 2000
The MOD Bit Modular Wood Boring System features quick-change cutter heads and replaceable pilot screws that increase labor efficiency and reduce tooling replacement costs. It uses a simple push-pull, quick-change system that makes removal and installation of different size Mod Bit cutter heads easy for the contractor. The task can be accomplished in three seconds, and no extra tools are needed to
The MOD Bit Modular Wood Boring System features quick-change cutter heads and replaceable pilot screws that increase labor efficiency and reduce tooling replacement costs. It uses a simple push-pull, quick-change system that makes removal and installation of different size Mod Bit cutter heads easy for the contractor. The task can be accomplished in three seconds, and no extra tools are needed to get the job done. Greenlee Textron
CEE NEWS STAFF
