Minimum Number of Outlets
The 2011 Code provides rules for the minimum number of receptacle outlets required in a dwelling unit.
Q. The 2011 Code provides rules for the minimum number of receptacle outlets required in a dwelling unit. This number shall be in addition to receptacle outlets that are _____.
a) part of a luminaire or appliance
b) controlled by a wall switch for use as required illumination
c) located more than 5½ ft above the floor
d) all of the above
The correct answer is: d) all of the above
Section 210.52 of the 2011 NEC provides requirements for 125V, 15A and 20A receptacle outlets installed in dwelling units.
