Bonding Screw Identification
Means of identification for bonding screw used as sole means of attachment
March 14, 2014
Where a main bonding jumper is a screw only, the screw shall be identified by a(n) _____ that shall be visible with the screw installed.
a) silver or white finish
b) green finish
c) etched ground symbol
d) hexagonal shaped head
The correct answer is: b) green finish
Section 250.28 of the 2011 NEC focuses on the main bonding and system bonding jumper requirements. As noted in 250.28(B), "where a main bonding jumper or a system bonding jumper is a screw only, the screw shall be identified with a green finish that shall be visible with the screw installed."
