Wiring Methods for PV Systems
The wiring methods permitted for solar photovoltaic systems can be found in Part IV of Art. 690.
Exposed PV source and output circuits operating at greater than _____ must be installed in a Chapter 3 wiring method anytime the conductors are installed in a(n) _____ location.
a) 30V, accessible
b) 30V, readily accessible
c) 60V, accessible
d) 60V, readily accessible
The correct answer is: b) 30V, readily accessible
The wiring methods permitted for solar photovoltaic systems can be found in Part IV of Art. 690. As noted in a portion of 690.31(A), "Where photovoltaic source and output circuits operating at maximum system voltages greater than 30V are installed in readily accessible locations, circuit conductors shall be installed in a raceway."
