Insulation Rating of Conductor Used in Lighting Equipment
Conductor construction and application rules are outlined in Table 310.104(A) through Table 310.104(E) of the 2011 NEC.
Sept. 16, 2014
THW insulation has a _____ rating when installed within electric-discharge lighting equipment, such as through fluorescent luminaires.
a) 60°C
b) 75°C
c) 90°C
d) 105°C
The correct answer is: c) 90°C
Conductor construction and application rules are outlined in Table 310.104(A) through Table 310.104(E) of the 2011 NEC. As noted in Table 310.104(A), THW insulation has a 90°C rating when installed within electric-discharge lighting equipment.
Mike Holt
Mike Holt
