Wiring Methods Within Vicinity of Aircraft
Article 513 applies to buildings or structures containing aircraft fuel or where aircraft are serviced or maintained.
Oct. 13, 2014
Within the vicinity of aircraft in an aircraft hangar, the area within 5 ft horizontally from aircraft power plants or aircraft fuel tanks shall be classified as a Class I, Division 2 location that extends upward from the floor to a level of _____ above the upper surface of wings and of engine enclosures.
a) 2 ft
b) 3 ft
c) 5 ft
d) 6 ft
The correct answer is: c) 5 ft
Article 513 applies to buildings or structures containing aircraft fuel or where aircraft are serviced or maintained. As per 513.3(C)(1), "The area within 5 ft horizontally from aircraft power plants or aircraft fuel tanks shall be classified as a Class I, Division 2 or Zone 2 location that shall extend upward from the floor to a level 5 ft above the upper surface of wings and engine enclosures."
Mike Holt
