GFCI Protection for Personnel
Section 210.8 of the 2014 NEC covers the requirements of ground-fault circuit-interrupter protection for personnel.
Jan. 19, 2015
In other than dwelling locations, GFCI protection is required in _____.
a) indoor wet locations
b) locker rooms with associated showering facilities
c) garages, service bays, and similar areas other than vehicle exhibition halls and showrooms
d) all of these areas
The correct answer is: d) all of these areas
Section 210.8 of the 2014 NEC covers the requirements of ground-fault circuit-interrupter protection for personnel. The three areas noted in a, b, and c above are noted in Sec. 210.8(B)(6), (7), and (8).
Mike Holt
Mike Holt
