Antenna Conductor Mounting Requirements
Article 810 covers the installation requirements for radio and television equipment.
Feb. 27, 2015
Antenna conductors for amateur transmitting stations attached to buildings shall be firmly mounted at least _____ in. clear of the surface of the building on nonabsorbent insulating supports.
a) 1
b) 2
c) 3
d) 4
The correct answer is: c) 3
Article 810 covers the installation requirements for radio and television equipment. As noted in Sec. 810.54, "Antenna conductors for transmitting stations, attached to buildings, shall be firmly mounted at least 3 in. clear of the surface of the building on nonabsorbent insulating supports, such as treated pins or brackets equipped with insulators having not less than 3-in. creepage and airgap distances. Lead-in conductors attached to buildings shall also comply with these requirements."
Mike Holt
Mike Holt
