Lighting Outlet Requirements in Attics and Underfloor Spaces
Article 210 of the 2014 NEC covers the requirements for branch circuits. Receptacle outlets shall be installed as specified in Sections 210.52 through 210.64.
For attics and underfloor spaces in other than dwelling units that contain heating, air-conditioning, and refrigeration equipment requiring servicing, at least one lighting outlet containing a switch or controlled by a wall switch shall be installed _____ the equipment requiring servicing.
a) at
b) near
c) a or b
d) none of the above
The correct answer is: c) a or b
Article 210 covers the requirements for branch circuits. Receptacle outlets shall be installed as specified in Sections 210.52 through 210.64.
As noted in Sec. 210.70(C), in other than dwelling units, at least one one lighting outlet containing a switch or controlled by a wall switch shall be installed in attics or underfloor spaces containing equipment requiring servicing, such as heating, air-conditioning and refrigeration equipment. "The lighting outlet shall be provided at or near the equipment requiring servicing."
Mike Holt
Mike Holt
