Cooper Crouse-Hinds Chico Speed Seal
The Chico SpeedSeal allows users to install an explosionproof seal in less than 5 min. The compound comes in a pre-measured, self-contained applicator so it requires no extra mixing equipment. Upon injection, the compound expands to fill the entire fitting, automatically separates the conductors, and hardens into a dense mass. It’s UL- and cUL-Listed for use with the manufacturer’s EYS sealing fittings
March 5, 2004
The Chico SpeedSeal allows users to install an explosionproof seal in less than 5 min. The compound comes in a pre-measured, self-contained applicator so it requires no extra mixing equipment. Upon injection, the compound expands to fill the entire fitting, automatically separates the conductors, and hardens into a dense mass. It’s UL- and cUL-Listed for use with the manufacturer’s EYS sealing fittings as large as 2 in.
