IPC Resistors release educational guides
IPC Resistors, Mississauga, Ontario, Canada, recently released two educational guides for electrical consultants and service contractors. Both the “Conversion Guide for Ungrounded Systems to High Resistance Grounding” and the “Consultant Specifications Guide to High Resistance Grounding” offer detailed technical information about ground fault protection. The “Conversion Guide for Ungrounded Systems
The “Conversion Guide for Ungrounded Systems to High Resistance Grounding” is designed to help consultants and service companies who are upgrading electrical systems from ungrounded to high resistance grounding. The guide covers the benefits of high resistance ground systems and provides step-by-step instructions for calculating grounding resistor size requirements to installation.
The “Consultant Specifications Guide to High Resistance Grounding” is designed to make specifications of grounding products easier for consultants. The guide contains template specifications for each of IPC’s grounding products.
For more information, visit www.ipc-resistors.com.
