KO Instruments' CBA-1000 Circuit Breaker Analyzer
With the CBA-1000, electricians no longer have to assume that single-pole, 120V/15A or 20A circuit breakers will perform as required. This instrument quickly and safely tests each branch circuit and its circuit breaker by conducting a precisely controlled short circuit, which will not overheat the line.
Feb. 12, 2004
