Leviton joins D-Tools to make product specification easier
Leviton recently announced it has joined the D-Tools Manufacturer Partner Program in an effort to streamline the process of specifying its products for residential applications. The Little Neck, N.Y.-based manufacturer is the first member company of the program. Systems designers can use the D-Tools System Integrator program to design and lay out wiring and communications schemes via graphic icons
June 3, 2002
Systems designers can use the D-Tools System Integrator program to design and lay out wiring and communications schemes via graphic icons and drag-and-drop menus. It also makes it easier for installers to sell upgrade packages in new construction and retrofit situations.
For more information, visit www.d-tools.com.
