Track lighting fixture
The Halo MiniLUME adjustable-beam ceramic metal halide, low-voltage track fixture is designed for 20W or 39W T4.5 lamps and is meant to replace 75W and 90W PAR halogen sources. The fixture’s housing rotates 300° and tilts 90° to eliminate dead zones. Detents align with beam angle icons to allow repeatability at spot, narrow flood, and flood positions. The front bezel can accept color filters and beam
The Halo MiniLUME adjustable-beam ceramic metal halide, low-voltage track fixture is designed for 20W or 39W T4.5 lamps and is meant to replace 75W and 90W PAR halogen sources. The fixture’s housing rotates 300° and tilts 90° to eliminate dead zones. Detents align with beam angle icons to allow repeatability at spot, narrow flood, and flood positions. The front bezel can accept color filters and beam modifying lenses. A glare shield provides additional cutoff.
Cooper Lighting
